Zyxel Nebula Smart Mesh Link
BCS
BCS Posts: 6 image  Freshman Member
edited April 2021 in Nebula
How can I tell if the link between the two Access Points is 2.4ghz or 5ghz?
I have enabled all display options but I can't find this information.
Thank you very much,
BCS
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @BCS
    NAP will use 5G to establish the WDS by default; however, it might use 2.4G if the 5G signal is not good enough. So far, we only can see the WDS detail via the AP SSH. This is a good idea for us to show the connection status on NCC. I will move this topic to idea, and hope it will be come true soon.
    Joslyn
  • BCS
    Hi @Zyxel_Joslyn
    Thanks for your answer,
    I think it's a great idea to be able to see the frequency of the link between the smart mesh access points, directly from NCC.
    I hope it will be implemented soon!
Nebula Tips & Tricks
