Jason
RTSP Edge setting on a nebula cloud-managed switches
matteosaitta
I have migrated my switches to nebula but i'm not seeing any way to sey my computers switchport into RSTP edge mode to avoid having to wait a long while for the port to come up. Are there any plan to add a way to modify the current nebula switch port properties pick from the current RSTP ON/OFF to say RTSP ON/ON-EDGE/OFF ?
Hi @matteosaitta ,
On Nebula Switch currently, all ports are edge-port by default when they are enabled RSTP.
Note: You may access your Switch via Telnet/SSH/Console and show running-config.
Hope it helps.
5
Hi @matteosaitta ,
Hope it helps.
Jason5
- 244 Nebula Ideas
- 6.9K Security
- 804 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
