What does RED Solid LED mean?
Zyxel_Support
During installation, if you observe the Red Solid LED, it means the Bluetooth isn’t working, please reboot the Multy Plus (WSQ60) node and try it again.
After installation is complete, Red Solid LED represents Internet disconnection is detected for the 1st node. Please check your Internet connection first.
After installation is complete, Red Solid LED on the 2nd node represents backhaul disconnection. Please make sure the 2nd node is not moved far from the 1st node. If it still shows Red Solid LED, please try to remove the 2nd node from the WiFi system and add it back again by using Multy App.
- 243 Nebula Ideas
- 6.9K Security
- 789 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 529 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
