Devices connecting to poor signal
DirtyEddie
I'm having issues with my devices connecting to the Multi. When my laptop is within a few get of the node it's connected to the other one further away, therefore poor signal strength and slower. I was told that my devices would connect to the nearest and strongest source. Apparently not. Anyone else having these issues?
#MultyX_Sep
#MultyX_Sep
Hi DirtyEddie,
Can you share the network adapter driver version and model of your laptop?
Please check the network adapter driver version of your laptop can support 802.11k/v or not.
Due to most laptop may not support 802.11k/v and has stronger RF capability than mobiles, it could still connect on Node 2 when it move near Node 1. (Maybe you can turn off and turn on wireless feature of your laptop to reconnect when it is close to Node 1.)
Hi Hanamichi, Thanks for the reply. I'm using a macbook pro retina 13" late 2015. Not sure how to find the network adapter driver version. But have have turned the wifi off and on. Still no change.0
Hi DirtyEddie,
I went through the literature on the subject.
It seems macOS does not yet support 802.11k and 802.11v.
https://support.apple.com/en-gb/HT206207
https://framebyframewifi.net/2017/08/20/macos-wi-fi-roaming/
Still having the same problem on the laptop. Also on several iPhones, iPads and desktop. Seems odd that all devices don’t connect automatically to stronger node and have to physically switch.0
May I know how do you check devices don’t connect automatically to stronger node?
And what is the distance between nodes? How is the signal strength of backhaul?
Is possible to share the screenshot? You can see below FAQ to check it.
https://homeforum.zyxel.com/discussion/1350/how-to-tell-where-the-extender-node-connects-to-in-the-network#latest
About the problem, below are several possible scenarios:
1. Maybe nodes are too close each other.
2. Most laptop/desktop may not support 802.11k/v and has stronger RF capability than mobiles, it could still connect on far node when it move near node. You may need to turn off and turn on wireless feature of your laptop to reconnect when it is close to that node.
3. Client device does not support 802.11k/v to cause it won't change connection when AP sent the steering suggestion. Steering behavior, it is depend on client device decision.0
- 241 Nebula Ideas
- 6.8K Security
- 758 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 518 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
