Firmware for new device
Chris_001
Chris_001 Posts: 2 image  Freshman Member
edited November 2018 in Smart Home Product
I have the VMG3925-B10A DSL modem/wireless router. This is the consumer version, and I can't find the latest firmware on the site. I currently have V5.13(ABNW.0)C0
https://www.zyxel.com/support/SupportLandingSR.shtml?c=gb&l=en&kbid=M-02409&md=VMG3925-B10B#searchZyxelTab2
This is the closest I could find, but it is not the same router. Are the guts the same? Is this the firmware I use?
#CPE_Nov_2018
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188 image  Zyxel Employee
    Sixth Anniversary
    Hi Chris_001,
    V5.13(ABNW.0)C0 is latest version for VMG3925-B10A. It cannot be updated to V513AAVF12b3 you find.
  • Zyxel_Support_CPE
    Sixth Anniversary
    Hi Chris_001,
  • Chris_001
    Thank you for the quick reply.
