NAS540-NAS542 UPNP and IP block for Dservice (bittorent)
sim_v
Hi;
UPNP configuration doesn't allow to open default 9090&9089 ports for the included bittorrent client (by the way which one is it ?).
I notice too a lot of blocked connection : "Download service blocked peer: 160.178..." even without block list.
regards,
Simon
#NAS_Feb_2019
#NAS_Feb_2019
is it block by router?
to check listen port for NAS, try these command: "losf -i", "netstat -tulpn"
IP are blocked by the NAS. I just changed the NAT configuration on my router : TCP only for 9090 et UDP only for 9089.
how about change use to transmission package?
it is also the tool for bittorrent download.0 -
I use my NAS away from LAN : included download service can be reach from admin console, I can transfert files with Files Browser and all is behind HTTPS and login/password.Transmission is better with LAN : no login !0
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
