Lte 5366 problem
Boris34
Boris34 Posts: 2 image  Freshman Member
edited January 2024 in Mobile Broadband
Hallo I'm italian.  I have a LTE5366 only connected with a 4g sim my provider is Tim. I have this problem, sometime the modem lose connection, I need to reboot it. The firmware is V1.00(ABKA.0)C0 . I have a pocket router and I haven't problem with the same Sim. Have you any  ad vice for me?
#LTE_Mar_2019
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188
    Sixth Anniversary
    image  Zyxel Employee
    Hi Boris34,
    May I know if you have external antenna on your device? If no, can you please help to check the setting of antenna selection? To configure it to “internal” and then check if this issue is resolved or not.
  • Boris34
    I have eterna antennaantennas and I set  the configurati on "external"
  • Zyxel_Support_CPE
    Sixth Anniversary
    Hi Boris34,
    May I ask your help to configure it to “internal” antenna to check if it can be fixed or not?
