A problem with Zyxel LTE5366-M608
maxg5
I bought a router Zyxel LTE5366-M608
I installed a sim card in the router. Only LTE network mode is turned on. Signal 4 divisions.
The problem is that every 3-5 minutes Internet access is lost. Helps restart the router.
Maybe something with the settings of the router?
What could be my problem?
Here is the log of the router:
#SP_Apr_2019
607 Apr 24 22:51:50 commander/change_dhcpd_ip_pool: Mask = 255.255.255.000 (ffffff00) - aka /24 608 Apr 24 22:51:50 commander/change_dhcpd_ip_pool: IP range start = 192.168.1.1 609 Apr 24 22:51:50 commander/change_dhcpd_ip_pool: IP range end = 192.168.1.254 610 Apr 24 22:51:50 commander/change_dhcpd_ip_pool: DHCP Server IP pool start = 192.168.1.33 611 Apr 24 22:51:50 commander/change_dhcpd_ip_pool: DHCP Server IP pool end = 192.168.1.64 612 Apr 24 22:51:50 commander/change_dhcpd_ip_pool: DHCP Server IP pool OKOK!! 613 Apr 24 22:51:50 commander: Start dnsmasq at nf_handle_dhcpsrv 614 Apr 24 22:51:50 udhcpd[21328]: Received a SIGTERM 615 Apr 24 22:51:55 MultiWANChk2: nat is restarting, skip checking 616 Apr 24 22:51:56 syslog: server_config.pool_check = 1 617 Apr 24 22:51:56 syslog: start = 192.168.1.33, end = 192.168.1.64, lan_ip = 192.168.1.1, interface=br0, ifindex=0 618 Apr 24 22:51:57 udhcpd[26022]: udhcpd (v0.9.9-pre) started 619 Apr 24 22:51:59 NAT/conntrack: flush start 620 Apr 24 22:52:00 MultiWANChk2: nat is restarting, skip checking 621 Apr 24 22:52:01 commander: WARN: NAT already running 622 Apr 24 22:52:04 NAT/conntrack: flush end 623 Apr 24 22:52:05 commander: handle_nat: nat restart 624 Apr 24 22:52:10 MultiWANChk2: nat is restarting, skip checking 625 Apr 24 22:52:11 NAT/conntrack: flush start 626 Apr 24 22:52:15 MultiWANChk2: nat is restarting, skip checking 627 Apr 24 22:52:16 NAT/conntrack: flush end
#SP_Apr_2019
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
