[VMG8825-B50B] Wireless printer stops functioning all of a sudden
oahnve
I have had a wireless Brother printer (DCP-L2530DW) connected to my VMG8825-B50B router without any problems for over 6 months. All of a sudden my computers can't print to it through the router.
The printer and the router are connected (the printer has an IP address and I can ping it from the admin interface), and the computer is connected to the same wifi network (no guest network or similar).
I have used the Brother connection tool, and I have also tried to add it directly through the computer (tried both Mac and PC) printer settings tools - but it says the computer can't find or can't control the printer.
The router has the latest firmware and I can't find anything within the settings that would disallow any device access to another device.
#SP_May_2019
#SP_May_2019
Did you put any new devices in your network?
No, nothing new. What would be an example of a device that could interfere?
I do have a wifi extender, and I tried removing that as well, to make sure it didn't interfere. Didn't help.0 -
hey, first of all thanks for posting because i am experiencing similar issue. can anyone provide solution??
thanks in advance.
best regards!!!Refer this insightful article now.0 -
Hi oahnve and SAMJOSEPHIf you said there has a IP with the printer can you ping to the IP from you computer?Since it has been working for 6 months before. If you try from the very beging, clean all the seeting on printer. And re-configration the pritner again, will it help?0
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
