Problem set up WRE6505 v2
Tintin1226
WiFi works well but connexion wasn't securized so I tried to to access the setup page by my android smartphone and my tablet.
I didn't succeed to open http://zyxelsetup or http://192.168.1.2
After a hard reset my tablet android 8.0 (or smartphone android 9.0) proposed me to reach the "password login" page.
password 1234 then when I push login button nothing happened..
I've tried several time with different browser.. same result.
Thanks for your answer.
#Repeater_Jul_2019
#Repeater_Jul_2019
I have tried the same steps, and it worked fine.
After the hard reset, the SSID of WRE6505 v2 would be "ZyXEL+(Last 6 charters of Mac Address)". I connected the SSID, and the login page would pop up, and the eaZy setting worked just fine.
What phone/tablet did you use?
Maybe you can do the setting on a computer, you can connect the PC directly to the Repeater via Ethernet cable, and type 192.168.1.2.0 -
I have the same problem all the time. I need to reset and configure again. This is exhausting.0
Hello @Jethronom,
Can you explain more detail information what kind of problem you encountered?
Do you mean, after WRE6505v2 worked for a while, all connection got fail, then you need to reset and re-configure? What is the firmware version of your WRE6505v2?
What is your network topology? How do you connect WRE6505v2?
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
