Bricked Zyxel Aurora camera after firmware upgrade
Koray
I just bought a zyxel aurora cam and alarm unit. Alarm unit did not work so i tried to start a firmware upgrade from my mobile phone. Now aurora cam does not start, it's led just lights up white and stays that way. I found firmware from the product page but there are no instructions to write firmware to aurora camera manually.
#Others_Aug_2019
#Others_Aug_2019
When you open Aurora App, does it show camera online or offline?
Is Zyxel Aurora Cloud Access Camera able to reset and reinstall?
I check the definition of LED, white means ready to record videos in low light.
Thank you for your reply. Aurora app does not show camera at all. I couldn't be able to reset and reinstall firmware, tried to press on-off button on the camera for the various durations with no success.. I can only shutdown camera by pressing power button for 10 seconds, thats all. I believe there was a problem with firmware update and now camera is bricked somehow. I wonder if it's possible to connect it to a computer in DFU mode.0
Here is the reset information from User's Guide.
Please make sure press the power button until you hear two beeps. If it still not works, I suggest you to contact ZYXEL local support.
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
