VMG3925-B10B in Bridge/Modem Only mode from LAN with single cable
sebus
I am trying to get to Zyxel VMG3925-B10B in Bridge/Modem Only mode from LAN driven by Mikrotik router
So the setup is client (wired or wireless) --> Mikrotik Eth1 --> single cable to VMG3925-B10B Eth1
From LAN client (192.168.88.1) I can ping the newly created Vlan2 interface on Mikrotik (192.168.2.1), but not the home networking/group interface on Zyxel (192.168.2.10)
Vlan2 is "attached" to Mikrotik Eth1 (which is used for PPPoE connection to Zyxel Eth1)
I can not ping Zyxel from Mikrotik itself either
Nothing from Zyxel to Mikrotik either, must be something to do with Vlan setup (most likely)
I have no idea, it didn't seem to when I tried.
Anybody has any ideas?
sebus
#SP_Mar_2020
</code><code>1 - login to UI of zyxel 2 - select networks -> vlan groups 3 - add group called bridge set vlan id to 2, tick the include box on the lan port you want to use (one used for wan) 4 - select networks -> interface grouping and assign bridge vdsl port to same lan port. Note you may have already done steps 3 and 4 when setting up the bridge. 5 - now select networks -> home networking 6 - in group name box default is preselected, change this to bridge 7 - make a note of the ip address shown, change if you want to. (to keep things simple change it to 192.168.2.10If I add ie Eth4 to Vlan Group on Zyxel (point 2 above), then connecting directly on that Eth4 I can access Zyxel unit via that IP, so it does work (just not the two together, yet)
</code><code>[admin@MikroTik] > ping 192.168.2.10
SEQ HOST SIZE TTL TIME STATUS
0 192.168.2.10 timeout
1 192.168.2.10 timeout
2 192.168.2.1 84 64 982ms host unreachable
3 192.168.2.10 timeout
sent=4 received=0 packet-loss=100% Nothing from Zyxel to Mikrotik either, must be something to do with Vlan setup (most likely)
</code><code>ZySH> ping
BusyBox v1.20.1 (2019-05-06 17:42:59 CST) multi-call binary.
Usage: ping [OPTIONS] HOST
Send ICMP ECHO_REQUEST packets to network hosts
-4,-6 Force IP or IPv6 name resolution
-c CNT Send only CNT pings
-s SIZE Send SIZE data bytes in packets (default:56)
-t TTL Set TTL
-I IFACE/IP Use interface or IP address as source
-W SEC Seconds to wait for the first response (default:10)
(after all -c CNT packets are sent)
-w SEC Seconds until ping exits (default:infinite)
(can exit earlier with -c CNT)
-q Quiet, only displays output at start
and when finished
ZySH> ping -4 192.168.2.1
^Ccommon_ping: hostname 192.168.2.1
PING 192.168.2.1 (192.168.2.1): 56 data bytes
--- 192.168.2.1 ping statistics ---
11 packets transmitted, 0 packets received, 100% packet loss
ZySH> ping -4 -I 192.168.2.10 192.168.2.1
PING 192.168.2.1 (192.168.2.1) from 192.168.2.10: 56 data bytes
5 packets transmitted, 0 packets received, 100% packet lossDoes this unit tag the output of the switch ports (in that config)? I have no idea, it didn't seem to when I tried.
sebus
#SP_Mar_2020
I see, nobody has any clue how Zyxel products work...
- 244 Nebula Ideas
- 6.9K Security
- 802 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
