EMG3425 Port Fowarding Help
NClack
I need some help with port forwarding on my EMG3425...
All of the guides I have come across show a NAT/Port Fowarding page that looks nothing like mine does, mainly that the field "Translation Port" is not present anywhere except my router.
I have a static IP setup with my ISP, and that is active, and I am trying to setup a VPN using port 1194.
The VPN server has been set up and has been assigned a static IP of 192.168.1.4 in my network.
When I attempt to setup my forwarding rule, using 1194 as both the port and translation port, I can never see it open from the outside.
What am I missing here?
#SP_Mar_2020
#SP_Mar_2020
Hi NClack,
May i know your Firmware Version ?
Based on my experience, the port forwarding page should here " Configuration-->Network > NAT > Port Forwarding"
Where can I find my current firmware version?
Looking through the entire menu I cannot find an entry for current firmware version, only the option to update firmware.
Port Forwarding IS Config > Network > NAT > Port Forwarding
My issue is that no matter what I set, I cannot open a port to the outside
I found it
V1.00(AAYJ.13)C0_20180921
Hi NClack,
I also have one HTTP server on port 1194, you can refer my setting below
Hope this could help you.0
- 244 Nebula Ideas
- 6.9K Security
- 796 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
