signal levels between aps
accurro
accurro Posts: 29 image  Freshman Member
First Comment Nebula Gratitude Fourth Anniversary
edited April 2021 in Nebula
for fine tuning of the wifi is it possible to extract from the system the signal strengths that each ap report that they see from and to each other?
likewise can the power levels of each individual ap be adjusted?
Best Answers
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @accurro,
    The power level of each AP can be configured individual by clicking the AP in Access point> Configure> Radio settings.
  • accurro
    thanks - needed some more detail as took a bit of time to actually find this setting - for anyone else also looking:
    Access Point > Configure > Radio >>  the main page just does power for all the APs - roll to bottom of page and select the AP you want from the list and then click the small edit on the top left.
  • Zyxel_Freda
    Hi @accurro,
  • accurro
  • accurro
    @Nebula_Freda
    thanks for the power setting bit but is the first part of the question asked possible?
    "for fine tuning of the wifi is it possible to extract from the system the signal strengths that each ap report that they see from and to each other?"
  • Zyxel_Freda
    Hi @accurro
    Sorry for missing the question. Currently, there's no AP detecting setting on the NCC to show the other APs' information. However, you may try to use below command via remote to the AP for checking.
    Router> _debug wireless_dbg wlanconfig wlan-2-1 list ap
    The wlan-2-1 means wlan-5GHz-SSID1, if you want to use 2.4GHz in SSID1, you can enter
    Router> _debug wireless_dbg wlanconfig wlan-1-1 list ap
    Although it can be checked via the command, it's recommended to scan the environment in station view, and you may use WiFi scan tool, like Winfi (windows OS) or AirPort (iOS).
    Thanks.
  • accurro
    thanks that's great CLI is fine will give it a test
Nebula Tips & Tricks
