Upgrade to ZLD 4.35 fail (Zywall 310)
When we try to update the firmware on Zywall 310, the firmware is downloaded, a reboot occurs and the entire firewall does not work. (wait for 20 min)
When we restart Zywall again, the old firmware is loaded, and the new one shows that it is not for Zywall 310, but for SHARE1100 ver 4.35 (YYYY.0) (as in the picture). We tried to update both automatically and through a local file. The firmware file was downloaded through the portal.myzyxel.com.
The result is the same.
Where to download the correct firmware file?
@Niviteka,
The behavior was mentioned on page 20 of the release note.
Select the Standby firmware row and click Reboot.After the device reboots, the correct firmware version is able to be shown on the web GUI.
5
You can log in here
select Firmware Download under Devices Management and find Zywall 310 firmware.
The firmware file was downloaded through the portal.myzyxel.com. The result is the same.PeterUK said:You can log in here
@Niviteka,
5
- 588 USG FLEX H Series
- 477 News and Release
