ISP "FIOS" - Router - VPN100 - L3 Switch
I am researching a device to use for web filtering, etc. The device will sit between router and a L3 switch. I do not want to replace my router. Will the VPN100 device work? I will not being using the VPN connection. Currently using a PC with UTM software. Want a device that will not throttle my 1GB internet connection.
Hi @masmith22
Welcome to the forum. I hope you will enjoy.
VPN100 fits your requirement (web filtering and 1Gb internet connection).
Obviously, in a Zyxel forum, you will receive only Zyxel devices recommendations,
Regards0 -
I would check to be sure that the VPN100 with web filtering turned on will deliver the throughput you expect.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
