ISP "FIOS" - Router - VPN100 - L3 Switch
I am researching a device to use for web filtering, etc. The device will sit between router and a L3 switch. I do not want to replace my router. Will the VPN100 device work? I will not being using the VPN connection. Currently using a PC with UTM software. Want a device that will not throttle my 1GB internet connection.
Hi @masmith22
Welcome to the forum. I hope you will enjoy.
VPN100 fits your requirement (web filtering and 1Gb internet connection).
Obviously, in a Zyxel forum, you will receive only Zyxel devices recommendations,
Regards0 -
I would check to be sure that the VPN100 with web filtering turned on will deliver the throughput you expect.0
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
