[NEBULA] The 10G Multi-Gig Switch XS3800-28 supports Nebula Cloud now!
Zyxel_Jason
Zyxel_Jason Posts: 429 image  Zyxel Employee
Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
edited April 2021 in Nebula
Hi all:
We are excited to announce that our powerful 10G Multi-Gig Switch XS3800-28 now supports Nebula, with 1-YEAR Pro-license! With this new 10G aggregation switch joining the Nebula family, you can now setup the entire cloud network and experience the centralized network management, zero touch provision, and many more Professional Pack features embedded with Cloud management. Sounds cool? All you need to do is follow these simple steps to enjoy the power of Nebula cloud management!
  1. Enable Nebula discovery on the XS3800-28 and make sure the switch is connected to Internet.
    *Required if you’ve previously deactivated NCC Discovery option or if you are running default Switch settings on V4.60(ABML.2) firmware
  2. Register the Switch to your Nebula Organization/Site.
  3. Once registered, it will take several minutes for the switch to automatically upgrade to the latest firmware V4.60(ABML.3).
    *While transition into cloud mode, the switch will be reset to its default configurations and synchronize with Nebula site settings.
 To find out more about our Nebula, visit Nebula Cloud Networking.
Jason
  • Eirik
    Eirik Posts: 2 image  Freshman Member
    I do not think that the switch is Nebula ready yet.
    All VLAN functionality is basically disabled, and every time we try to update (any) VLAN settings from Nebula, it disables VLAN trunking for all ports. We are now trying to restore the switch to standalone mode.
    It's a great idea, but, sadly, poorly executed.
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    It sounds great.
  • Zyxel_Jason
    Hi @Eirik ,
    I would like to PM you for more details of the issue you encounter.
    Please help to check your Inbox of Forum.
    Thanks.
    Jason
  • Zyxel_Jason
    Hi All,
    Just update the result from private message.
    VLAN trunking is enable by default in cloud mode.
    It will be disable when the user configures Allowed VLANs(not allow all) on Trunk port.
    Thanks.
    Jason
Nebula Tips & Tricks
