Upgrade to ZLD 4.35 fail (Zywall 310)
Niviteka
Niviteka Posts: 17 image  Freshman Member
edited April 2021 in Security
When we try to update the firmware on Zywall 310, the firmware is downloaded, a reboot occurs and the entire firewall does not work. (wait for 20 min)
When we restart Zywall again, the old firmware is loaded, and the new one shows that it is not for Zywall 310, but for SHARE1100 ver 4.35 (YYYY.0) (as in the picture). We tried to update both automatically and through a local file. The firmware file was downloaded through the portal.myzyxel.com.
The result is the same.
Where to download the correct firmware file?
    PeterUK Posts: 4,411 image  Guru Member
    You can log in here
    https://portal.myzyxel.com
    select Firmware Download under Devices Management and find Zywall 310 firmware.
  • Niviteka
    PeterUK said:
    You can log in here
    The firmware file was downloaded through the portal.myzyxel.com. The result is the same.
