[NEBULA] What are the AVP for Radius that accepts Nebula CC?
Hi @yomismo,The max download and upload attributes are not supported by NAP so far.However, if you want to limit the bandwidth, you can use 'Rate limiting' in AP > Configure > SSID.It can be supported to limit the download and upload for each client who connected to the SSID.
Thanks.5
Hi @yomismo,May I know the radius AVP of which Nebula products you want to know?Is there any specific attribute you want to use/check?Please share the information for us and we'll help to check if it's supported in Nebula devices.Thanks.0
Hello Freda!We are using NAP203 with firmware up to date.We would like to use the Max download and upload bandwidth.Thanks in advanced,
Thanks.5 -
OK Freda,Thanks for your answer,Regards0
Hello again,
Is it possible to use an Idle timeout attribute?
Thanks in advanced,0 -
Hello @yomismo ,
The idle timeout attribute is not supported yet, and going to support in Jan. 2020.
Thanks.0 -
Thanks for your answer.
Regards.1
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
