[NEBULA] What are the AVP for Radius that accepts Nebula CC?
Hi @yomismo,The max download and upload attributes are not supported by NAP so far.However, if you want to limit the bandwidth, you can use 'Rate limiting' in AP > Configure > SSID.It can be supported to limit the download and upload for each client who connected to the SSID.
Thanks.5
Hi @yomismo,May I know the radius AVP of which Nebula products you want to know?Is there any specific attribute you want to use/check?Please share the information for us and we'll help to check if it's supported in Nebula devices.Thanks.0
Hello Freda!We are using NAP203 with firmware up to date.We would like to use the Max download and upload bandwidth.Thanks in advanced,
Thanks.5 -
OK Freda,Thanks for your answer,Regards0
Hello again,
Is it possible to use an Idle timeout attribute?
Thanks in advanced,0 -
Hello @yomismo ,
The idle timeout attribute is not supported yet, and going to support in Jan. 2020.
Thanks.0 -
Thanks for your answer.
Regards.1
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
