Why is CPU 30% on USG 210. Incoherencies in CPU statistiques
frerealexis
frerealexis Posts: 21  Freshman Member
edited April 2021 in Security
On the dashboard, the CPU is at 25%. But the graphic shows 40%. DEBUG SYSTEM PS reveals a sum of 3%. And CPU/MEMORY STATUS in DIAGNOSTICS reveals also about 3%. All APP WIRELESS features are disactivated. So I have 2 questions
1. why are there such incoherences in CPU stats ?
2. what is the real CPU ? and if it is 25% what service is concerned ?
  • USG_User
    USG_User Posts: 397  Master Member
    Connect to Web Console or CLI Console (after logged-in) and type "show cpu average". This is showing you the CPU utilization, devided for each core. Additionally you will see the most CPU occupying services of the USG.
  • frerealexis
    Interesting but it doesn't really answer the question about incohérences between CPU stats.
    What period is used for calculating the average ? 24 hrs ? Since last reboot ?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,418  Zyxel Employee
    Hi @frerealexis,
    When you enter the command on console, the value of the "CPU utilization" is the CPU (Core 0) usage at the moment you enter the command.
    For example, when I enter the command "show cpu status" at 17:00, the CPU utilization at the moment 17:00 is 3%.
    The average of CPU utilization of the previous 5 minutes (16:55-17:00) is 1%.
    Router> show cpu status
    CPU utilization: 3 %
    CPU utilization for 1 min: 0 %
    CPU utilization for 5 min: 1 %
    To monitor all cores of CPU usage, go to MAINTENANCE > Diagnostics > CPU/Memory Status.
    On the graph of CPU, the dot is generated by the average CPU usage of every 5 minutes. The dot is not generated by every second.
