[Release Note] Zywall Series - V4.35 firmware has been released!
Zyxel_Emily
Zyxel Zywall Series
Release Note
October 2019
Firmware Version on below models
USG20-VPN USG20W-VPN USG110 USG210
USG40 USG40W USG60 USG60W
USG310 USG1100 USG1900 USG2200
ZyWALL 110 ZyWALL 310 ZyWALL 1100
New Feature and Enhancements
For more details, please refer to the below Link.ftp://ftp.zyxel.com/USG110/firmware/USG110_4.35(AAPH.0)C0_2.pdf
Notes for the latest security gateway firmware:
We've made some changes to better serve you. Please log into your myZyxel account to obtain the latest firmware, ZLD4.35 for ZyWALL USG security gateway. Moreover, you can also online upgrade the latest firmware from cloud helper on ZyWALL Series . Don't have an account yet? Sign up.
Well,appearently my running 4.33 config is considered "bad" by 4.35 - of course without any indication why.What a great Job Zyxel!
Hi, I had a similar problem.
My workaround (you should be at the location of the USG in this moment ;-)): after the upgrade to v4.35 - apply your saved v4.33-startup-config - "Ignore errors and finish applying the configuration file".
compare the old v4.33 and the new v4.35 config to find the differences (in my case: it was a NAT-Rule).
I was able to add the missing NAT-Rule (with a shorter description).
A case was opened, the problem is confirmed, a hotfix-FW is available from the Zyxel Support.
BR, MJR0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
