[NEBULA] speed issues
Jurgen_1975
Internet speed from cable going in is 850kb/s. Out of the Nebula is only 100kb/s.
Running NSG200 with two NSW-100-28P switches.
Anti-virus is on.
Any thoughts?
thanks
Anti-virus is on.
Any thoughts?
thanks
Hello @Jurgen_1975
Welcome to the community!
May I know how you test it is the speed test? And can you please temporary disable the Anti-virus and test it again, thank you.
/Chris0 -
Hi Chris,
Speed test is done trough cable connected directly to modem or firewall.
When i deactivate the anti virus the speed is perfect but when activated max 100 kb/s.
When i read the specs the max speed with anti virus activated is 300 kb/s?
thanks
Jurgen
Hello @Jurgen_1975 ,
Please be aware that the speed spec. in datasheet is Mb/s not kb/s, may I confirm with you that your network speed is Mbps or Kbps?
/Chris
Hi Chris,
My bad, speed is in Mbps. So nevertheless with anti virus activated i am only getting output speed of max 100 Mbps.
thanks
Any update please?
ok thanks
- 588 USG FLEX H Series
- 477 News and Release
