WAC6303D-S is missing antenna pattern
Hi @bbros ,
Do you mean the Antenna setting in AP > Configure > Radio?
The feature is only supported by NAP203 and WAC6103D-I, so there's no selection on WAC6303D-S' configuration.
Thanks.0 -
The WAC6303D-S has a built-in smart antenna and that will do the trick, so I don't think the antenna pattern is needed for this model. Am I right?
"You will never walk along"1 -
Hi @RUnglaube,
Yes, you'r right and thank for comment. :)
Right, sorry! I've confused the products! '-.-
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
