Issue with L2TP IPSEC VPN on V4.35 firmware
We had been using V4.30 firmware for over one and half year. Its L2TP VPN worked fine for us. We never really had connection issue.
Recently we upgraded to V4.35 firmware, we now started to see L2TP VPN connection issue on Mac. VPN tunnel is established, but users can not connect to any internal website. When this happened, I tried ping internal IP address, it didn't work. I had to reboot router to make it work.
Have anyone here seen similar VPN issue with V4.35 firmware?
Would you please double check the ports that are allowed from WAN to ZyWall (firmware notation) if 1701 UDP is still allowed.
Also, double check the firewall rules from IPSec zone and L2TP subnet to LAN1 zone and subnet.
Thanks for the suggestion. I added 1701 UDP. It didn't help. I also add a policy to make sure traffic from L2TP subnet to LAN zone and subnet, but it doesn't make difference.
It failed again today. I rebooted once, it didn't work. I had to reboot for the second time for it to work. Since this happens very often, I am thinking reverting to old firmware version.
Hi @Brady,
We need the configuration file to check the symptom. I will contact you in private message for more information.
Thanks!
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
