Unable to ping 8.8.8.8
Merryworks
Merryworks Posts: 3 image  Freshman Member
edited April 2021 in Security
Trying to get a Pitney Bowes mailer to work and during it's self test, it attempts to ping 8.8.8.8. It gets no response. I have tested pinging from a separate computer on the same network and am getting no response from 8.8.8.8. I am getting responses from 1.1.1.1 and 9.9.9.9. My DHCP pool has 8.8.8.8 as the secondary DNS. Not sure what I am missing. Device is a USG20-VPN. Firmware is 4.35(ABAQ.0)
  • Zyxel_Emily
    Hi @Merryworks,
    Can you provide network topology with IP/subnet?
    You can hide the public IP.
    It could be that your ISP is blocking 8.8.8.8 as your able to ping 1.1.1.1 and 9.9.9.9.
    can you connect a PC to the modem without USG20-VPN to ping 8.8.8.8
  • Merryworks
    My guess is ISP. Thanks
