USG20W-VPN - cannot edit AP Object Profile
Hi there , I have updated the firmware on our USG20W-VPN box to the latest firmware (4.35 ABAR .0) and the Wifi is a lot more stable. It still drops out every day but I can handle that for the moment. What I cannot do is edit the AP Profile. When I go to 'Configuration...Object..AP Profile..' and try to edit the 5G profile ( which I'm using) I get a message telling me that the configuration can only be edited min easy mode. I have looked and there is no way that I can see to edit the AP profile in easy mode. What am I missing?
Thanks in advance
moon moth
OK...looks like I can edit the other 5G profile. I will try that instead.
Mm
Mm
Yes, as I understand in the new firmware these profiles specially "only for the easy mode". If need something different - need to create a new AP profile.
Yes, turns out that I needed to edit the other 5g profile. Sorted.
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 919 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 926 Nebula FAQ
- 422 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
