DNS Suffix no more working on USG-310 after uprading Firmware at V4.35
have you found a solution?
after the update I can't ping the pc inside the main lan from any pc in any vlan without inserting the dns extension in the name ... to understand ping pc1 it goes in failed request, while ping pc1.mydomain.local successfully completes the ping.
Hi @Assitek,
It works on both firmware 4.33 and 4.35.
Here is my test result for your reference.
If your settings are the same as mine but it is still not working, feel free to share the configuration file with me in private message.
Configure DNS suffix in vlan11.
Create an address record.
Connect PC to vlan11. It successfully gets IP 192.168.19.5 and DNS suffix cso.com.
On one PC in LAN, ping “test” successfully.
Hy Zyxel_Emily
the configurations are almost identical
my problem is that with my pc connected on vlan 4 (wifi) with ip 10.59.3.x I can't resolve the names on the main VLAN 192.168.1.x
Which before the upgrade to 4.35 worked perfectly
I am obliged to put the dns extension to resolve the name
note (I'm doing nslookup on DNS SERVER)
reverting the firmware to 4.33 everything starts working perfectly again
Marco
- 588 USG FLEX H Series
- 476 News and Release
