ip address zyxewl usg 40
damianodec
damianodec Posts: 42 image  Freshman Member
edited April 2021 in Security
hi, on my zyxel there is a label with ip address (wrote in the first configuration) 192.168.10.254 but when I try to connect it by browser I do not get login screen but error link...
how can I to get right IP address ? have I to reset it ?
thank you
  • damianodec
    by IP scanner I see IP 192.168.10.254 but ping it and not reply
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,461 image  Zyxel Employee
    Hi @damianodec,
    Connect console to USG40 and use the following commands to check the status.
    1. Check the IP address of each interface
    Router> show interface all
    2. Check the physical port of a certain interface
    Router> show interface <interface name>
    3. Check the port of HTTPS and from which zone the administrator can use HTTPS to access the web GUI.
    Router> show ip http server secure status
    4. List all firewall rules and check if the access from a specific interface to ZyWALL for HTTPS is allowed or denied.
    Router> show firewall any any
  • damianodec
    hi @Zyxel_Emily
    thank you, I'm try to connect usg 40 and COM1 by connect cable and Putty software:
    Serial port, COM1, 115200, OPEN
    but windows of connection give me just a green cursor on the top/left corner and nothing "welcome connections"...
    any help?
  • Zyxel_Emily
    Hi @damianodec,
    Try to use the Tera Term and you can select the correct COM port from the list.
  • damianodec
    hi @Zyxel_Emily
    I had to reset firewall
    thank you.
