Error Zyxel Service is terminated
Same sh.. happened to me right now - what is the fix?0
I'm having the same type of problems with USG210 running on FW4.35.
frerealexis said:I'm having the same type of problems with USG210 running on FW4.35.
Zyxel. Zyxel never changes...
YES, on FW 4.35. And rebooting doesn't solve anything. In fact the reboot does not work. After rebooting I had to unplug the device. And this morning, I have once again the same message.
I have disactivated all authentification rules and the USG sees to be back to normal.
Finally, it seems that the problem comes from FQDN groups for which I created security rules. After disactivating these rules, the message ERROR ZYXEL SERVICE IS TERMINATED does not appear and CPU is back to normal.
iv got the same problem now on my zywall310. restart is not working
Hi @AntonProf
Which firmware is working on your device?
Can you upgrade to 4.38 firmware first and check if it help in your case ?
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 292 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 253 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
