No access to switch XS3700-24
Janbolat
Janbolat Posts: 3  Freshman Member
edited August 2022 in Switch
I can't access to switch with WEB-Interface and Telnet.
I access to switch with console, but many errors on it.
To access with telnet I only can reboot the switch. But I have to enter to switch without reboot to backup configuration. If I reboot the switch without backup, I can lost data.
How can I enter to switch?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,798  Guru Member
    Hi @liaoweihan,
    I will send the file to you via private message. Please check your community message box.
    Zyxel Melen
