NSG Security Gateways support UPNP
Hello @steves
NSG don't support UPNP in current stage, I will put this idea to our feature queue and also move this post to the idea section anyone who likes this can leave your comment or press like button below.☺️
/Chris
@Nebula_Chris I would like to use upnp, because my customers use it for their music
Upnp is a security risk.
A virus, Trojan horse, worm, or other malicious program that manages to infect a computer on your local network can use UPnP, just like legitimate programs can. While a router normally blocks incoming connections, preventing some malicious access, UPnP could allow a malicious program to bypass the firewall entirely.
So my recommendation is not supporting Upnp.
Regards
In an enterprise or business situation, I agree... But we have a fair number of larger residential customers that want a managed network and UPnP is very beneficial in that environment. I was not looking for a blanket solution for all customers, but the Nebula product is priced properly to do managed residential networks, both single family and multi-family dwellings, and UPnP is beneficial with a multitude of gaming and mutlimedia applications used often in homes and some of the other possible security issues are alleviated with the built in content and security measures of the NSG appliances.
It is a "wish list" item though.
I am more than fine with this as a solution, as not having it enabled would be more common than having it enabled. We probably install these 85% in enterprise scenarios and 15% in residential, so having it disabled by default would be better but it would sure be nice to have that for the residential installations.
Hello @steves and Alfonso,
Thanks for your suggestion and share the business background information for us, noted it and will keep collecting the feedback on this post.?
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
