FW-Upgrade standard behaviour: -> "Ignore errors and finish applying the configuration file"
mjr
In case of a failure during a FW-update (i.e. from v.4.33 to v4.35) the USG falls back to default config and will be in an unconfigured condition. There is no simple possibility to do further remote administration.
IDEA:
Please add a choice - before the FW-upgrade starts - like when applying a configuration file:
IDEA:
If applying the configuration file encounters an error:
-- Immediately stop applying the configuration file |
-- Immediately stop applying the configuration file and roll back to the previous configuration |
-- Ignore errors and finish applying the configuration file |
-- Ignore errors and finish applying the configuration file and then roll back to the previous configuration |
I agree that, at the bare minimum, it should be applying the last successful running configuration. I'd be surprised if it wasn't doing that already, though, unless, perhaps, the config you're currently using is failing to load properly in 4.33 and generating errors?
Incidentally, I haven't had a configuration fail, yet, but I'll be doing a swath of upgrades tomorrow, so I'll report back if I find the same issue.
- 603 USG FLEX H Series
- 481 News and Release
