Problem - Zyxel USG-100 PLUS - FTTH Fiber Limit to 100 mbit/s
Hello to all,
I have an FTTH fiber connection with an Aethra BG8542EW router, and if I connect my PC directly to the router I reach 380 mbit / s in download. (Router ---> PC)
If instead I connect my PC to my Zyxel USG 100 Plus Firewall
(Router ---> Firewall Zyxel ---> PC) , the download speed does not exceed 100 mbit / s.
Why does Zyxel reach a maximum of 100 mbit / s ???
Thank you in advance!
Good morning,
I don't understand, if there is a solution for me.
Is there anything in the configuration that I can modify to solve?
Thanks!
Hi @kernel24,
Use the command “show port setting” to check if the negotiation is auto.
In our lab, ISP is 300 Mbps.
Router ---> USG100-PLUS ---> PC
The download speed is 220 Mbps using speedtest.
Sorry for my ignorance...
how do I get this command?
Start "web console" at the most upper right corner, after logged into your device. This will open an additional browser window with the web console where you have to log-in again. Then you could type the commands.
I've tried it all the way, but there's a problem with java.
I installed it, uninstalled it, reinstalled it but nothing.
I've tried using Internet Explorer, Chrome and Firefox ... always the same problem (see attached image ).
Is there an alternative?
if you have upgraded to v4.35 Java is not longer necessary! The web console will start in an additional browser window.
That device has not been upgraded to 4.35.
Hi @kernel24,
The firmware 4.35 doesn't support on USG100-PLUS.
The web console is not working on USG100-PLUS because of Java is not supported.
By default, the negotiation is auto.
You can check if the status of the wan interface is 1000M/Full on dashboard.
this is my "Interface Status Summary"
- 588 USG FLEX H Series
- 477 News and Release
