ip address zyxewl usg 40
hi, on my zyxel there is a label with ip address (wrote in the first configuration) 192.168.10.254 but when I try to connect it by browser I do not get login screen but error link...
how can I to get right IP address ? have I to reset it ?
thank you
by IP scanner I see IP 192.168.10.254 but ping it and not reply
Hi @damianodec,
Connect console to USG40 and use the following commands to check the status.
1. Check the IP address of each interface
Router> show interface all
2. Check the physical port of a certain interface
Router> show interface <interface name>
3. Check the port of HTTPS and from which zone the administrator can use HTTPS to access the web GUI.
Router> show ip http server secure status
4. List all firewall rules and check if the access from a specific interface to ZyWALL for HTTPS is allowed or denied.
Router> show firewall any any
hi @Zyxel_Emily
thank you, I'm try to connect usg 40 and COM1 by connect cable and Putty software:
Serial port, COM1, 115200, OPEN
but windows of connection give me just a green cursor on the top/left corner and nothing "welcome connections"...
any help?
Hi @damianodec,
Try to use the Tera Term and you can select the correct COM port from the list.
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 295 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
