How setup Zywall USG 60 with amazon VPC ?
Hi ,
I have tried to set up AWS VPC via VPN setup Wizard or manually and I have same issue after successfully installation ,
I can see My IPsec VPN is up in My side firewall but in AWS side there is only the IPSec is Up and Tunnel status is Down ?
Do I missing something on my USG set up or can some one tell me step by step how do set up USG60 with AWS VPC .
Regards
Jari
Hi @JariP,
You can follow the guide in this discussion thread to modify the configuration file downloaded from AWS and then upload it to USG.
5
Hi @JariP,
5
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
