navigation slow on some websites
Device: ZyWALL USG 200
Firmware:
Boot Module: 1.13
Current Version: 3.30(AQU.7)
Released Date: 2015-01-13 16:31:04
Problem: On some site (surely tested with amazon.it and ebay.it but it appens randomly) the loading time on first call is about 10 seconds before the site appear, then the navigation works correctly. If i leave the page open for a few minutes the site takes again about 10 seconds to restart working.
The problem dosn’t appear if i connect my device directly to the router
Configuration:
router on wan1 with static ip, lan on lan1 with static ip
What i’ve done ‘till now to solve the problem:
deactivated firewall, BWM, Antivirus, ADP, IDP and Content-filter.
Set session per host to 0 in firewall->session control (also tried to deativate it )
Set google DNS servers on system->DNS (not needful but i’ve tried).
Really don’t know what to do please help.
Hi @paolo_brignone,
The latest firmware for ZyWALL USG 200 is sent to you in private message.
It's good to hear that you confirmed everything works properly after firmware upgrade. ?
5
Hi @paolo_brignone,
Can you share the startup-config.conf with us in private message to check the symptom?
Hi @paolo_brignone,
5
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
