USG40: Can't get port forwarding working anymore
Hi
I have used port forwarding for a number of years in a USG20 and a USG40, and they have worked well.
Recently I have added two more port forwards in my USG40, but none of them works. A port scan shows that the ports are not open.
I then tried to delete one of my well working forwards (NAT, SecPolicy, Objects), and created it again. Now this is also not working.
Any ideas what is going wrong now? Soon getting some grey hair from this....
My USG40 has v4.35.
br Lars
Hi
It finally showed up to be all devices that passed my switch Zyxel GS 1920-24. It was kind of working, but had to be turned off/on to get failing devices to work again. Never seen that before.
How are the USG setup? drawing of the network setup.
Are the ports TCP?
Is one of the USG getting the WAN IP and your using Virtual Server? Screenshots.
Thanks for responding. Issue has now changed somewhat. Discovered that it was only for port forwards where I also have port translation ongoing (so ext port != int port). So currently investigating somewhere else.
Hi @larsras,
Here are some examples of port forwarding for your reference.
If you still have questions about port forwarding, share the topology and screen shot of NAT and security policy rule settings with everyone in this discussion thread.
Hi
- 441 Beta Program
- 293 Service & License
