NWA5123-AC HD 3rd Device Low Link Speed - Fixed Bad Cable
iSpeed
iSpeed Posts: 110 image  Ally Member
edited May 2024 in Wireless
Updated. I had a bad cable that was not transmitting at full gig speed.
Ok I'm on my third access point and this one is now saying low link speed. I believe it started after updating to latest firmware.
  • Zyxel_KathyLin
    Zyxel_KathyLin Posts: 58 image  Zyxel Employee
    First Answer First Comment Friend Collector
    Hi @iSpeed
    Is your AP get the full gig speed when you use the normal cable?
    If no, could you enable the zyxel support on the Nebula control center and send me the private message with the org/site, I can help you to check the AP status.
  • iSpeed
    It was a bad cable. Thanks for responding.
