[NEBULA] Force clients to connect 2,4
ticsystems
ZCNE Certified
ZCNE Certified
Hi!!!
I need force to connect only one device to 2,4.
The 5Ghz band not working for this device.
How can i do???
Thanks!!!!!
Hi @ticsystems,
Usually, Nebula AP broadcast SSID for 2.4G and 5G as the default setting (concurrent). And, if the client is not supported 5G, the SSID for 5G should not be visible, so the client can only see and connect to 2.4G.
Thanks.0
- 238 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
