NWA5123-AC HD 3rd Device Low Link Speed - Fixed Bad Cable
Hi @iSpeed
Is your AP get the full gig speed when you use the normal cable?
If no, could you enable the zyxel support on the Nebula control center and send me the private message with the org/site, I can help you to check the AP status.0 -
It was a bad cable. Thanks for responding.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 482 News and Release
