Smaller Aggregation Switch
Hey there,
we're having a smaller network (about 8 switches) and would like to upgrade them to 10G switches. However there aren't currently any devices available which are affordable for a small company which simply needs an aggregation switch with e.g. 10x 10G SFP+ ports. There's a huge pricing gap between the XGS1930 10G switches and the XS3800-28. Currently we're using an aggregation switch from a different vendor, but we really would like to replace it with a zyxel one.
The only available option is the XS3800-28, but it's very expensive and has a lot of ports we don't need.
The XS1920-12 is a very good switch, but it sadly doesn't support SFP+, which is very mandatory for an aggregation switch. And if you need RJ45 you can simply put an SFP+-RJ45 Transreceiver in it.
Are there any plans to build a newer version of the XS1920-12 switch with nebula cloud support and SFP+? This would be awesome.
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 318 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 450 News and Release
- 4.3K FAQ
- 93 Security Highlight
