Extended range feature not working properly
Sakura_T
Sakura_T Posts: 101  Ally Member
edited August 2022 in Switch
Hi
Just got the new model Zyxel GS1350-12HP switch and try to use the "extended range" .
After enabling the feature in web interface, I then connected my ethernet cable (around 250 meters) from switch to my ip cam.
Somehow the ip cam can only have the PoE power but no data transmission, so it won't work at all.
Anything have I missed?
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126  Zyxel Employee
    Hi @Sakura_T
    May I know what model is your IP camera?
    Also, what kinds of ethernet cable you use? (Cat5? Cat6?)
    Zyxel_Derrick
  • Sakura_T
    Hey @Zyxel_Derrick
    My camera is Samsung Hanwha WiseNet QNO-7080R, and the cable is common CAT5e.
    Should I change to CAT6 one? It's kind of expensive to me.
  • Zyxel_Derrick
    edited December 2019
    Hi @Sakura_T
    We have other customers use the same IP camera as yours and also use 250M CAT5e ethernet cable but no issue happen.
    Sometimes the quality of ethernet cable may have an impact on data transmission
    Therefore, we suggest shortening the cable length and test again if the issue still exist
    Also, if possible, you can change to CAT6 of course due to the higher quality it has
    Best regards,
    Zyxel_Derrick
  • Sakura_T
    @Zyxel_Derrick
    Thanks for the reply, I'll try shorter CAT5e cable and keep you posted.
  • Sakura_T
    Just tested with 220m CAT5e cable and my ipcam is now working like a charm.
    It does seem to have something to do with the cable quality, I'm guessing it can work in 250m if the cable is CAT6 or 7?
  • Username_is_reserved
    Username_is_reserved Posts: 115  Ally Member
    Hi
    I would buy a S/FTP Cable only. You must take care that the Cable and Shield is propper Made.
