[NEBULA] LAN connected AP shows as Wireless
At one of our sites we have 2 Nebula 102 Acces points showing as wireless uplink in the control center despite them beeing conntected through LAN (both PoE).
Both devices are have the latest firmaware and ofc. tried restarted.
Anyone here who has experienced any similar issues?
Hi @Enur,
As you mentioned that the AP were connected with PoE, may I know if the Ethernet LAN to which the AP is connected can reach the GW that goes to internet?
If not, then device will try to connect using wireless mesh, so the status is correct. Or, if the Ethernet cable can reach GW, please let me know your org/site via PM. I'll help to check this issue.
Thanks.
- 588 USG FLEX H Series
- 477 News and Release
