[NEBULA] LAN connected AP shows as Wireless
Enur
Enur Posts: 3 image  Freshman Member
First Anniversary
edited April 2021 in Nebula
At one of our sites we have 2 Nebula 102 Acces points showing as wireless uplink in the control center despite them beeing conntected through LAN (both PoE).
Both devices are have the latest firmaware and ofc. tried restarted.
Anyone here who has experienced any similar issues?
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @Enur,
    When the AP is in repeater mode, it will show the uplink: Wireless in AP info page.
    Thanks.
  • Zyxel_Freda
    Hi @Enur,
    As you mentioned that the AP were connected with PoE, may I know if the Ethernet LAN to which the AP is connected can reach the GW that goes to internet?
    If not, then device will try to connect using wireless mesh, so the status is correct. Or, if the Ethernet cable can reach GW, please let me know your org/site via PM. I'll help to check this issue.
    Thanks.
Nebula Tips & Tricks
