Question to the other users. Do you have similar problem?
Martin_Kuchar
Martin_Kuchar Posts: 38
image  Freshman Member
edited April 2021 in Security
I am already tested workaround with Zyxel staff, but I want to know if also othe users here have similar problem. In system logs, with "debug" on, after some days from USG reboot, we see many error messages like this:
kernel: warn_alloc_failed: 17 callbacks suppressed
kernel: swapper/2: page allocation failure: order:4, mode:0x200020
The result is lost internal route for SSL VPN logged-in users. The users simply cannot see internal network, nor can ping internal computers.
This is some sort of memory allocation problem and I need to know if also others have this problem or it is only our case. We do not have extreme traffic. Just 15-20 people behind USG and 1-3 remote users. Internet usage is typical for office work, nothing special.
Thanks to all for research and reply,
Martin Kuchar
  • Martin_Kuchar
    Kernel panics was resolved with help of @Zyxel_Emily . In case of questions, you can contact me with private message.
