Firmware 4.35 issue bug
Grant
Grant Posts: 48  Freshman Member
First Answer First Comment Friend Collector Sixth Anniversary
edited April 2021 in Security
zywall-zw1100
When viewing sessions by the criteria - users, the device turns into a "pumpkin". Happy New Year!
  • Grant
    Now i'm use 4.33 version and
    no time for experimentation.
  • Grant
    Only a cold restart helps turn a pumpkin into a carriage.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,418  Zyxel Employee
    Hi @Grant,
    With both firmware 4.35(AAAC.0) and 4.35(AAAC.2), there is no problem viewing sessions by users.
    Can you collect diagnostic file for our analysis?
  • Grant
    All connections are lost. I can not connect to the console.
  • Zyxel_Emily
    Hi @Grant,
    After you reboots the device, go to Diagnostics to collect diagnostic file.
  • Grant
  • Zyxel_Vic
    Zyxel_Vic Posts: 310  Zyxel Employee
    25 Answers First Comment Friend Collector Seventh Anniversary
    Hi @Grant
    Do you have the idea about how many concurrent sessions in average will go through your Zywall 1100? Perhaps we can simulate a bunch session test and see if it can be seen in our office.
    Moreover, how frequently will this symptom occur? Will it happen regularly?
  • Grant
    It happens regularly.
  • Zyxel_Vic
    Hi @Grant
    Thanks for the confirmation, we'll do some further double checking on this part to see if it can be reproduced.
