AP Firmware - unable to reset the download path to "official"
We've got some problems with regular reboots of our Zyxel AP WAC6103D-I. That's why Zyxel provided us with an interim firmware (v5.40(ABIM.2)) which works so far. For the download we had to change the download path for the capwap firmware.
Now we've updated our USG110 to 4.35 (AAPH.2) and would like to change the download path to Zyxel Cloud Server back to official. Ths has been done by CLI commands:
Router# configure terminal
Router(config)# capwap firmware-update source official
After that we've made a manual firmware check (Button "Check"). The "Last Check Success:" shows "success, 2019-12-30 08:34:24, means the connection to official server should work. But the USG Configuration (Wireless>AP Management>Firmware) is still showing: "Device can't connect to cloud server" at the line WAC6103D-I
How could I fix it?
Hi Joerg,
It is because the AP firmwares of NWA5123-AC and NWA5123-AC-HD have been included in USG firmware. After upgrading the USG firmware, the AP firmwares will also be saved on the USG as well. That's why you will see both of the lines are black and showed local.
About the storage is full, USG will delete the AP firmware which is not used and try to download the AP firmware that you need automatically. That's why you will see the status of NWA5123-AC-HD has been gray, and WAC6103D-I has been black.
It seems work in your environment. Good to hear about that.
Appreciate for your help in this period.
Thanks again. :)
Joslyn
5
Hi @USG_User
Could you help to collect below information on USG110 for us?
Router# nslookup zapimg.cloud.zyxel.com
Router# _debug capwap show inter-ap-fw-table
Router# _debug capwap show cloud downloading table
We want to realize if your USG can can reach the cloud server successfully.
Moreover, is there any system logs when the error message showed up?
Thanks.
Joslyn
Hi Joslyn,
Please find the requested information as follows:
Trying "zapimg.cloud.zyxel.com"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 34827
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 4, ADDITIONAL: 4
;; QUESTION SECTION:
;zapimg.cloud.zyxel.com. IN ANY
;; ANSWER SECTION:
zapimg.cloud.zyxel.com. 172800 IN CNAME zapimg.cloud.zyxel.com.s3-website-us-east-1.amazonaws.com.
;; AUTHORITY SECTION:
cloud.zyxel.com. 86400 IN NS ns2.p09.dynect.net.
cloud.zyxel.com. 86400 IN NS ns3.p09.dynect.net.
cloud.zyxel.com. 86400 IN NS ns4.p09.dynect.net.
cloud.zyxel.com. 86400 IN NS ns1.p09.dynect.net.
;; ADDITIONAL SECTION:
ns1.p09.dynect.net. 54998 IN A 208.78.70.9
ns2.p09.dynect.net. 54998 IN A 204.13.250.9
ns3.p09.dynect.net. 54998 IN A 208.78.71.9
ns4.p09.dynect.net. 54998 IN A 204.13.251.9
apFwSource: official
fwCheckStatus: 1
fwCheckTimestamp AP: 2019-12-30 08:50:08
runtimeApFwVersion: 5.40(.2)
downloadedApFwVersion: 5.40(.1)
runtimeApImageInfo total number: 18
runtimeApImage0:
modelId: 1ae1
fwName: wac6500
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage1:
modelId: 1be1
fwName: wac6500
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage2:
modelId: 1ce1
fwName: wac6500
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage3:
modelId: 1de1
fwName: wac6500
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage4:
modelId: 42e1
fwName: wac6500
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage5:
modelId: 43e1
fwName: nwa5123-ac-hd
storage: /share/wtp_image
status: finish
process: 100.000000
error log: -
runtimeApImage6:
modelId: 1b00
fwName: nwa5kcn50
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage7:
modelId: 9503
fwName: nwa5kcn50
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage8:
modelId: 9603
fwName: nwa5kcn50
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage9:
modelId: 9b03
fwName: nwa5kcn50
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage10:
modelId: 15e1
fwName: nwa5301
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage11:
modelId: 37e1
fwName: wac5300
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage12:
modelId: 25e1
fwName: wac6100
storage: -
status: pending
process: 0.000000
error log: Device can't connect to cloud server.
runtimeApImage13:
modelId: 3ee1
fwName: wac6300
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage14:
modelId: 9d03
fwName: nwa5120
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage15:
modelId: 7e1
fwName: nwa5120
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage16:
modelId: 8e1
fwName: nwa5120
storage: -
status: pending
process: 0.000000
error log: -
runtimeApImage17:
modelId: 26e1
fwName: nwa5123-ac
status: finish
process: 100.000000
error log: -
Pid Type Need Check Storage URL
The cloud downloading table as well as the AP systems log are empty.
Cheers
Joerg
Hi @USG_User
It seems some AP firmware downloading status is pending, only WAC6100 shows the error message. Could you collect one more information for us?
Router> _debug capwap dbg-flag cloud enable
Apply this CLI, then do the same action as "Check" the AP firmware, then "Apply" the AP firmware. After finishing, please disable the debug message.
Router> _debug capwap dbg-flag cloud disable
Please help to use this CLI to print the logs then provide it to me.
Router> _debug show file /tmp/cw_dbg_log
Thanks.
Joslyn
Hi Joslyn,
I've carried out the a.m. CLI commands. "Checking" the AP firmware brought no new FW, and "Applying" caused to a pop-up window "Runtime firmware and available firmware are the same version".
Here the results from cw_dbg_log:
Router# _debug show file /tmp/cw_dbg_log
2019/12/27 10:48:41,capwap_mgnt_fw.c:776:
Error opening mmct file : /db/wtp_image/cwinfo!!
2019/12/27 10:48:41,capwap_mgnt_plugin.c:282:open failed!
2019/12/27 10:48:41,capwap_srv.c:2141:@@@capwapSrvTask:Don't run main task until system is ready
2019/12/27 10:48:57,capwap_srv.c:2499:Not RUN state(RunTimeInfo Type: 4). wtp state 0
2019/12/27 11:49:48,capwap_mgnt_cloud.c:3517:Download error, return code 4, error massage Device can't connect to cloud server.
2019/12/27 11:50:00,capwap_mgnt_cloud.c:3517:Download error, return code 4, error massage Device can't connect to cloud server.
2019/12/27 11:50:00,capwap_mgnt_cloud.c:3599:AP firmware wac6100 download fail 2 times, exit!!
2019/12/27 11:50:18,capwap_srv.c:1350:fwName = wac6100 download fail 2 times, accept to RUN state.
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3681:Receive EVENT_CAPWAP_GET_CLOUDFIRMWARE_AP_STATUS
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3414:Receive EVENT_CAPWAP_GET_CLOUD_AP_FW_STATUS
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3451:Receive EVENT_CAPWAP_GET_RELEASE_NOTE
2020/1/7 09:19:26,capwap_mgnt_cloud.c:447:capwapCloudGetReleaseNoteUrl: Get cloud url is http://www.zyxel.com/solutions/AP-Controller-Technology-20140627-854642.shtml
2020/1/7 09:19:30,capwap_mgnt_cloud.c:3348:Receive EVENT_CAPWAP_CLOUD_CHECK.
2020/1/7 09:19:30,capwap_mgnt_cloud.c:408:Get cloud source is official.
2020/1/7 09:19:30,capwap_mgnt_cloud.c:1445:LatestVersion doesn't exist
2020/1/7 09:19:30,capwap_mgnt_cloud.c:1034:python /usr/local/share/zydownloader.pyc -v -l /tmp/cloud_download.log -d /tmp -c 1024 -r 3 -b /usr/local/bin/capwap/cloud_callback http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion .
2020/1/7 09:19:30,capwap_mgnt_cloud.c:1641:Start download http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion, REAL_FILE
2020/1/7 09:19:30,capwap_mgnt_cloud.c:968:Add download job, pid = 17794, url = http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion, downloadType = REAL_FILE, storageIdx = 1
2020/1/7 09:19:30,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:32,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:33,capwap_mgnt_cloud.c:3479:Receive EVENT_CAPWAP_CLOUD_DOWNLOAD_FINISH, msg 17794 0
, msg len 9
2020/1/7 09:19:33,capwap_mgnt_cloud.c:3524:EVENT_CAPWAP_CLOUD_DOWNLOAD_FINISH: VERSION_FILE
2020/1/7 09:19:33,capwap_mgnt_cloud.c:408:Get cloud source is official.
2020/1/7 09:19:33,capwap_mgnt_cloud.c:2217:capwapCloudFinishVersionProc download Successfully
2020/1/7 09:19:33,capwap_mgnt_cloud.c:2227:runtimeVersion 5.40(.2), downloadVersion 5.40(.2), latestVersion 5.40(.2)
2020/1/7 09:19:35,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3681:Receive EVENT_CAPWAP_GET_CLOUDFIRMWARE_AP_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3414:Receive EVENT_CAPWAP_GET_CLOUD_AP_FW_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3451:Receive EVENT_CAPWAP_GET_RELEASE_NOTE
2020/1/7 09:19:54,capwap_mgnt_cloud.c:447:capwapCloudGetReleaseNoteUrl: Get cloud url is http://www.zyxel.com/solutions/AP-Controller-Technology-20140627-854642.shtml
Router#
Hi @USG_User ,
Thanks for your information.
From the logs, I did not see the error message as "Device can't connect to cloud server". Was the issue gone? Did you still see the error on the GUI? If no, could you share with me what you did for it?
Thanks.
Joslyn
Hi Joslyn,
Still the same error message. See my screenshot below of today:
Hi @USG_User ,
Thanks for your detail information. We thought we have found the root cause and tried to fixed it now. Will update to you the solution later. You did a big help for us. Thank you so much!
Joslyn
It's a pleasure.
Hi @USG_User ,
The issue has been fixed. Could you try to check then apply the AP firmware on USG110? Please let me know if the error message is gone or not.
Thanks.
Joslyn
Hi Joslyn,
Thanks for your effort. Unfortunately nothing has changed.
I'm able to check the available firmware (via Button "Check") which shows (after a few seconds): "success, 2020-01-08 08:43:51".
Then I try to apply the fw (via Button "Apply"). But this still cause to the popup window "Runtime firmware and available firmware are the same version." And that's it. WAC6103D-I is still not able to connect to cloud server.
Nevertheless the AP is working properly and all WLAN clients are able to connect.
By the way: Why the firmware table is showing firwares for AP "NWA5123-AC-HD" (table line 6) and "NWA5123-AC" (table line 20). We've got only one AP (WAC6103D-I) in operation with the USG110. But these other two AP firmwares are being shown for months and have no relation with the current error for WAC6103D-I
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 465 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
