AP Firmware - unable to reset the download path to "official"
Hi @USG_User
Apologize to cause your any inconvenience.
Could you collect the debug logs for us again?
Router> _debug capwap dbg-flag cloud enable
Apply this CLI, then do the same action as "Check" the AP firmware, then "Apply" the AP firmware. After finishing, please disable the debug message.
Router> _debug capwap dbg-flag cloud disable
Please help to use this CLI to print the logs then provide it to me.
Router> _debug show file /tmp/cw_dbg_log
Thanks.
Joslyn
Hi Joslyn,
No problem and no need for apologizing. We are happy with this exellent support. Here is the log:
Router# _debug capwap dbg-flag cloud enable
Router# _debug capwap dbg-flag cloud disable
Router# _debug show file /tmp/cw_dbg_log
2019/12/27 10:48:41,capwap_mgnt_fw.c:776:
Error opening mmct file : /db/wtp_image/cwinfo!!
2019/12/27 10:48:41,capwap_mgnt_plugin.c:282:open failed!
2019/12/27 10:48:41,capwap_srv.c:2141:@@@capwapSrvTask:Don't run main task until system is ready
2019/12/27 10:48:57,capwap_srv.c:2499:Not RUN state(RunTimeInfo Type: 4). wtp state 0
2019/12/27 11:49:48,capwap_mgnt_cloud.c:3517:Download error, return code 4, error massage Device can't connect to cloud server.
2019/12/27 11:50:00,capwap_mgnt_cloud.c:3517:Download error, return code 4, error massage Device can't connect to cloud server.
2019/12/27 11:50:00,capwap_mgnt_cloud.c:3599:AP firmware wac6100 download fail 2 times, exit!!
2019/12/27 11:50:18,capwap_srv.c:1350:fwName = wac6100 download fail 2 times, accept to RUN state.
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3681:Receive EVENT_CAPWAP_GET_CLOUDFIRMWARE_AP_STATUS
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3414:Receive EVENT_CAPWAP_GET_CLOUD_AP_FW_STATUS
2020/1/7 09:19:26,capwap_mgnt_cloud.c:3451:Receive EVENT_CAPWAP_GET_RELEASE_NOTE
2020/1/7 09:19:26,capwap_mgnt_cloud.c:447:capwapCloudGetReleaseNoteUrl: Get cloud url is http://www.zyxel.com/solutions/AP-Controller-Technology-20140627-854642.shtml
2020/1/7 09:19:30,capwap_mgnt_cloud.c:3348:Receive EVENT_CAPWAP_CLOUD_CHECK.
2020/1/7 09:19:30,capwap_mgnt_cloud.c:408:Get cloud source is official.
2020/1/7 09:19:30,capwap_mgnt_cloud.c:1445:LatestVersion doesn't exist
2020/1/7 09:19:30,capwap_mgnt_cloud.c:1034:python /usr/local/share/zydownloader.pyc -v -l /tmp/cloud_download.log -d /tmp -c 1024 -r 3 -b /usr/local/bin/capwap/cloud_callback http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion .
2020/1/7 09:19:30,capwap_mgnt_cloud.c:1641:Start download http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion, REAL_FILE
2020/1/7 09:19:30,capwap_mgnt_cloud.c:968:Add download job, pid = 17794, url = http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion, downloadType = REAL_FILE, storageIdx = 1
2020/1/7 09:19:30,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:32,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:33,capwap_mgnt_cloud.c:3479:Receive EVENT_CAPWAP_CLOUD_DOWNLOAD_FINISH, msg 17794 0
, msg len 9
2020/1/7 09:19:33,capwap_mgnt_cloud.c:3524:EVENT_CAPWAP_CLOUD_DOWNLOAD_FINISH: VERSION_FILE
2020/1/7 09:19:33,capwap_mgnt_cloud.c:408:Get cloud source is official.
2020/1/7 09:19:33,capwap_mgnt_cloud.c:2217:capwapCloudFinishVersionProc download Successfully
2020/1/7 09:19:33,capwap_mgnt_cloud.c:2227:runtimeVersion 5.40(.2), downloadVersion 5.40(.2), latestVersion 5.40(.2)
2020/1/7 09:19:35,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3681:Receive EVENT_CAPWAP_GET_CLOUDFIRMWARE_AP_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3414:Receive EVENT_CAPWAP_GET_CLOUD_AP_FW_STATUS
2020/1/7 09:19:54,capwap_mgnt_cloud.c:3451:Receive EVENT_CAPWAP_GET_RELEASE_NOTE
2020/1/7 09:19:54,capwap_mgnt_cloud.c:447:capwapCloudGetReleaseNoteUrl: Get cloud url is http://www.zyxel.com/solutions/AP-Controller-Technology-20140627-854642.shtml
2020/1/8 09:58:46,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/8 09:58:46,capwap_mgnt_cloud.c:3681:Receive EVENT_CAPWAP_GET_CLOUDFIRMWARE_AP_STATUS
2020/1/8 09:58:46,capwap_mgnt_cloud.c:3414:Receive EVENT_CAPWAP_GET_CLOUD_AP_FW_STATUS
2020/1/8 09:58:46,capwap_mgnt_cloud.c:3451:Receive EVENT_CAPWAP_GET_RELEASE_NOTE
2020/1/8 09:58:46,capwap_mgnt_cloud.c:447:capwapCloudGetReleaseNoteUrl: Get cloud url is http://www.zyxel.com/solutions/AP-Controller-Technology-20140627-854642.shtml
2020/1/8 09:58:50,capwap_mgnt_cloud.c:3348:Receive EVENT_CAPWAP_CLOUD_CHECK.
2020/1/8 09:58:50,capwap_mgnt_cloud.c:408:Get cloud source is official.
2020/1/8 09:58:50,capwap_mgnt_cloud.c:1445:LatestVersion doesn't exist
2020/1/8 09:58:50,capwap_mgnt_cloud.c:1034:python /usr/local/share/zydownloader.pyc -v -l /tmp/cloud_download.log -d /tmp -c 1024 -r 3 -b /usr/local/bin/capwap/cloud_callback http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion .
2020/1/8 09:58:50,capwap_mgnt_cloud.c:1641:Start download http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion, REAL_FILE
2020/1/8 09:58:50,capwap_mgnt_cloud.c:968:Add download job, pid = 1457, url = http://zapimg.cloud.zyxel.com/ZAP8/LatestVersion, downloadType = REAL_FILE, storageIdx = 1
2020/1/8 09:58:50,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/8 09:58:53,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
2020/1/8 09:58:53,capwap_mgnt_cloud.c:3479:Receive EVENT_CAPWAP_CLOUD_DOWNLOAD_FINISH, msg 1457 0
, msg len 8
2020/1/8 09:58:53,capwap_mgnt_cloud.c:3524:EVENT_CAPWAP_CLOUD_DOWNLOAD_FINISH: VERSION_FILE
2020/1/8 09:58:53,capwap_mgnt_cloud.c:408:Get cloud source is official.
2020/1/8 09:58:53,capwap_mgnt_cloud.c:2217:capwapCloudFinishVersionProc download Successfully
2020/1/8 09:58:53,capwap_mgnt_cloud.c:2227:runtimeVersion 5.40(.2), downloadVersion 5.40(.2), latestVersion 5.40(.2)
2020/1/8 09:58:55,capwap_mgnt_cloud.c:3424:Receive EVENT_CAPWAP_GET_CLOUD_CHECK_STATUS
Router#
Hi @USG_User
We found another way to download the AP firmware.
1.Go to CONFIGURATION>Wireless>AP Management>AP Policy>Firmware Updating. Please change the updating mode as "Manual". Then apply the setting.
2.Go to MONITOR>Wireless>AP Information>AP List. Choose WAC6103D-I and click the "upgrade FW".
The AP firmware should be started downloading and applying. In this upgrading period, the AP might stop wifi service. Please help to confirm if it helps.
Thanks.
Joslyn
Hi Joslyn,
I've carried out the a.m. procedure. Using the "Upgrade FW" Button at the AP List table brought no reaction, neither an error message nor a download progress bar.
But some seconds later we received an alert notification e-mail from our USG110 with the content: "AP firmware download failed. Reason: Device storage is not enough. File name: wac6100"
But there should be enough storage space at our USG
Joslyn,
Now I've changed back the update mode to "Auto".
And surprise, surprise, when checking the AP Management FW Table I could see the following:
Line 6 is disabled now - this is correct since we do not have a NWA5123 in place. And for the line WAC6103D-I the error message is gone ?
Could you tell me why the line 20, NWA5123-AC is still available at the table? We do not have such an AP in place.
But anyway. It seems we got it now. Many many thanks for your effort and greetings from Germany
Joerg
Hi Joerg,
It is because the AP firmwares of NWA5123-AC and NWA5123-AC-HD have been included in USG firmware. After upgrading the USG firmware, the AP firmwares will also be saved on the USG as well. That's why you will see both of the lines are black and showed local.
About the storage is full, USG will delete the AP firmware which is not used and try to download the AP firmware that you need automatically. That's why you will see the status of NWA5123-AC-HD has been gray, and WAC6103D-I has been black.
It seems work in your environment. Good to hear about that.
Appreciate for your help in this period.
Thanks again. :)
Joslyn
5
- 211 Nebula Ideas
- 543 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
